Direkt zum Inhalt
How to Print with Mix Color and Gradient on Sovol SV02? Official Tutorial
Set Mixer mode
(Before starting please make sure that you installed mix-color extruder kit on sovol sv02 and flashed the mix color printing firmware for the touch screen and mainboard. )
On the white frame, you can adjust the parameters of mixing color, the value can be among 0 to 100, the left one is for extruder 1, the right one is for extruder 2. During the printing, the pringing page will show the mode and the propotion of the mixing color.
Set Gradient Mode
On Mixer page, hit Actve V-tool , you can  adjust the parameters,the value can be among 0 to 15.
Hit Gradient, you can enter Gradient page, and hit Aisa V-tool to adjust the parameters, the value can be among 0 to 15. The value of Actve v-tool and Alisa V-tool should be same.
Start Z means the height of the  beginning. End Z means the height of the ending,
The value of Start Z should be less than the model. In the printing process, the page will show the mixing model and the mixing proption
Mode Change
During Printing , you can change the mixing color printing mode anytime. For example. you set gradient mode before printing, and in the printing process, you hit Adjust and enter Adjust page, then hit Mixer and enter Mix page to change the current mode and the mix color propotion.
Warenkorb 0
Dein Warenkorb ist leer
Beginn mit dem Einkauf
